show mpls rsvp-te profile fast-reroute
show mpls rsvp-te profile fast-reroute {detail}
Description
Displays the configuration for all fast-reroute profiles.
Syntax Description
detail Displays the profile information in verbose format.
Default
N/A.
Usage Guidelines
None.
The following command displays summary configuration information for all fast-reroute profiles:
# show mpls rsvp-te profile fast-reroute
FRR Profile Name Mode   Bandwidth SPri HPri HopLmt P-BW P-Node #LSP
default_frr      Detour        10    7    0      3 Dis  Ena       4
prf1_frr         Detour         0    7    0      3 Dis  Ena       2
The following command displays detailed configuration information for all fast-reroute profiles:
# show mpls rsvp-te profile fast-reroute detail
Profile Name : prf1_frr
Peak Rate            : 0 Kbps
Committed Rate       : 0 Kbps
Max Burst Size       : 0 Kb
Setup Priority       : 7
Hold Priority        : 4
Hop Limit            : 1
Protected BW         : Off
Protect Node         : On
#LSP References      : 2
LSP / Path           : pc10_lsp / p1
Profile Name : default_frr
Peak Rate            : 0 Kbps
Setup Priority       : 4
Hold Priority        : 0
Hop Limit            : 2
Protected BW         : On
Protect Node         : On
#LSP References      : 4
LSP / Path           : pc_frr_lsp / p2
Platform Availability
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
